vitoi
LabVIEW for Arduino Due
Status: Completed
Available in LabVIEW 2020 Community Edition and later. The Community Edition includes the LINX Toolkit, which provides support for programming Arduino devices. Only the Arduino Uno was officially tested, but other Arduino devices may work as well.
The Arduino Due is a 32 bit ARM based microcontroller board that is destined to be very popular. It would be great if we could programme it in LabVIEW. This product could leverage off the already available LabVIEW Embedded for ARM and the LabVIEW Microcontroller SDK.
The Arduino Due is currently in developer trials and is due out later this year. It is expected to be about $50 and is open hardware. The ARM chip is an Atmel SAM3X8E ARM Cortex M3 running at 84 MHz resulting in 100 MIPS of performance. By way of comparison, the current LabVIEW Embedded for ARM Tier 1 (out-of-the-box experience) boards have only 60 MIPS of processing power.
The Arduino brand has an enormous following and Google has selected the Arduino Due for their recently introduced (28 June 2012) Accessory Development Kit for Android mobile phones and tablets (the ADK2012).
(By the way, the currently-available LabVIEW Arduino toolkit does not target the Arduino (and couldn’t since the Arduino Uno uses only an 8 bit microcontroller). Instead there is fixed C code running on the Arduino to transfer peripheral information to the serial port and back. That is, none of the LabVIEW target code executes on the Arduino. This idea is for LabVIEW code developed on a desktop to be transferred and execute on the target Arduino Due.)
Wouldn’t it be great to programme the Arduino Due in LabVIEW?
24 Comments
Y3G
I am using LV2009 with the Arduino Toolkit and it worked ok for the UNO. Now I have the DUO and would like to continue. Are there still no VIs available?
Many thanks in advance
Y3G ...when ther is LTE
vitoi
The Arduino Toolkit does not provide a mechanism for programming the Arduino. Instead there is some fixed C code loaded onto the Arduino that mearly bridges the Arduino's I/O with the Arduino's comm port. This idea is for the ability to write LabVIEW code that executes on the Arduino Due.
CarlosOtiniano
...always interesting to program a microcontroller in LabVIEW but if we use arduino, this will become a DAQ, when we need to work with an autonomous robot such as this has problems, moreover one aalternativa NI plate them with the LM3S8962 microcontroller but apparently IT and will continue to not support this device brondando level 1, hopefully news
ManuelKeel
Hi
the arduino due has quite similar hardware to the lego nxt brick. Would it be possible to load the nxt firmware to the arduino and then programm the arduino with Labview (with the nxt toolkit)?
I tink it should be possible, wath you tink?
best regards.
vitoi
Would be far better if NI did this work once and promoted LabVIEW, rather than each of us try to make it work.
NewtonCuri
Is coming  a way to use LabVIEW in Arduino !
See at  http://www.3d-svs.com/news/80-3dmicro-toolkit-arduino-expansion-beta-out
...and enjoy!
Note: NI also sells this products.
vitoi
NewtonCuri, how much does it cost to use this (not evaluation)?
PrincyLS
Arduino based labview program need
RavensFan
Knight of NI
PrincyLS,
Then vote for the idea by clicking the Kudo button.  Just saying you need it in a comment doesn't rate the idea any higher.
vitoi
Interestign kudos profile for this idea:
2012: 91 kudos (and it started on 07-16-2012)
2013: 19 kudos
2014: 8 kudos
2015: 0 kudos
2016: 0 kudos
By the way, kudos rate has dropped across the board since the new website format.
