| User | Kudos |
| 1 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
There have been several ideas proposed to alleviate accidentally savings vis in the wrong version of LabVIEW. While useful, I think the main problem is that LabVIEW doesn't use the information it reads from the file to preserve compatibility. I'd like to propose here that LabVIEW introduce compatibility modes for previous releases in which LabVIEW will break a VI if a feature is introduced that isn't supported by the compatibility version. It will essentially be a built-in, seamless "save for previous" mode.
By default, LabVIEW will load a VI (hierarchy) in a compatibility mode for whichever version is was saved in. If the user tries to make a change that isn't compatible, LabVIEW will alert the user and the user can tell LabVIEW whether it's ok to save to a newer version that supports the feature.
The level of alerts can be configurable, of course.
Related ideas:
Version-aware LabVIEW launcher
Add header to LabVIEW file to contain the version of LabVIEW
