There are many tasks in LabVIEW that are tedious and manual due to its graphical nature. This is something Nigel or another LLM-controlled scripting feature could change.
Allow it to perform structural changes and wiring on the block diagram via natural language commands. Expand it’s capabilities beyond explanation and simple code suggestions to direct, intelligent manipulation of the Front Panel and Block Diagram. The user should be able to describe desired behavior in plain English, and the AI should execute or generate the appropriate structure.
One example would be wiring and bundling: “Wire all controls whose names contain ‘sensor’ to a Bundle By Name node using the matching cluster element names.”
Another might be diagram layout: “Select all terminals containing ‘temp’ and arrange them by the last number in their name vertically on the right side of the diagram with tight spacing.”
Desired Capabilities:
