User | Kudos |
3 | |
3 | |
2 | |
2 | |
2 |
I just used the space constant VI from the string pallet. (I don't really now why I use this one sometimes because you can easily create it by yourself, mostlikely because of the icon )
When I then checked the VI properties of "Space constant.vi" I noticed that the "Inline subVI into calling VIs" checkbox was not marked in the execution tab. I don't think it will do anyone harm to make this VI inline, can it? I also came to think of it that there are most likely other small VI's from National Instruments which maybe should have Inline marked, maybe NI should take a look threw the small VIs?
Maybe, maybe it is even an idea the LabVIEW check the contents of a string and if it sees that it is a constant space, line feed, etc it changes to its respectable constant icon.
