ChrisFarmerWIS
Include Temporary Path terminal to NI_HTML.lvclass:Print Report.vi
Status: Declined
Can we include a Temporary File Path terminal to NI_HTML.lvclass: Print Report.vi, and consequently NI_ReportGenerationCore.lvlib: Print HTML Report.vi.
NI_HTML.lvclass: Print Report.vi will merely pass this path down into NI_ReportGenerationCore.lvlib: Print HTML Report.vi.
In NI_ReportGenerationCore.lvlib: Print HTML Report.vi, if Temporary File Path is Not a path, then continue to create a temporary file path.  If it does exists, then add some code at the end to clean up the temporary file.
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
https://wiredinsoftware.com.au
2 Comments
ChrisFarmerWIS
The main reason behind this request, is so that when one is using a 3rd Party PDF printer, then the path & filename will be sent through to the Save As dialog prompt of the 3rd Party PDF printer
Christopher Farmer
Darren
Proven Zealot
Status changed to: Declined
