User | Kudos |
2 | |
2 | |
2 | |
2 | |
1 |
It is many times easiest to work with data in the form of an array. Also helpful in many situations to use arrays inside of clusters. This is a problem when working with functions that require a data type to be a fixed size since they don't accept the combination. I'm asking for full support for fixed-size arrays in Labview and LabviewRT.
See example problems attached. Also open to other ideas as long as they are similarly elegant and easy to use. Also please correct me if I haven't shown the simplest workarounds, etc.
(also possible this is a bug but seems to be a missing feature)
