User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
If you install anything (anything!) from NI on a computer that runs windows 8 or newer, you will get bugged by a dialog to disable fast startup. The option is enabled by default, no matter what you install. It will popup with every single install, even minor patches, and even if this option has been intentionally unchecked in the original installation to be patched. If you don't want to disable fast startup, it is a never-ending whack-a-mole of these dialogs. (... but the need to disable fast startup for some scenarios is a more general problem that NI needs to address. It could be a new idea, but I think NI is aware of this problem. It might even be something that Microsoft could address such that devices don't get lost in the scenarios where fast startup causes problems)
This idea is centered around executables that we built and distribute via installers..
While this option (=disabling fast startup) can be useful when certain DAQ hardware is used, it makes absolutely no sense for other LabVIEW programs. Most of my programs don't use any DAQ hardware and it is not reasonable to globally cripple every single computer that has them installed. People tend to click [next] without reading, assuming that the defaults are typically reasonable.
Currently, this install query can be silenced by editing the setup.ini and changing the entry "WinFastStartup=1" to "WinFastStartup=0". I have built dozens of applications over the last few days and it is becoming seriously annoying to constantly remember to do that.
I suggest that the installer builder should get another checkbox that allows us to set that option permanently. Here is how it could look like.
IDEA SUMMARY: Allow us to configure the fast startup dialog from the installer builder tool.
