User | Kudos |
23 | |
8 | |
5 | |
4 | |
4 |
When I was newer to LabVIEW, I found it hard to understand how people could identify front panel object styles e.g. NXG style string control vs System string control.
I believe it is the sort of skill that takes experience and experimentation, and it only gets more complex when the appearance of the string control is customised. For example, modifying the above controls so they are the same size, they are practically identical...
I have never been able to find a good complete documentation of the differences in appearance and behaviour between different styles of front panel object - seems each style of each type of control has their quirks. So when presented with front panel objects that you did not make yourself, it is hard to 'reverse engineer' them if changes are needed. This makes it harder to learn how to make good UIs.
A potential solution would be to add a property which tells you which style a control or indicator was created as, or most recently replaced by. E.g. modern, classic, system, silver, NXG. An extension would be to add a 'reset to default style' which would behave as if replacing the customised object with an object of that style from the palette. A further extension would be to allow changing of style e.g. in this example from NXG to System via a dropdown box, although not all front panel objects are available in all styles so I can see this being more difficult to implement.
This is probably the ugliest UI mockup you will see all day but I hope it gets the idea across and sparks some conversation:
This would be accessed via 'properties' on the right click menu of the front panel object.
I'm not very experienced with XControls, QControls etc. so would welcome suggestions about how these should behave. Perhaps there is some nuance to do with styles that I am missing.
This idea is related to this one which talks about setting style for the whole front panel.
Let me know your thoughts!
