my suggestion is to make it optional within the eventstructure to execute code on each event, before the event specific code will be executed, like follows:
Please see the following example for a better understanding of my suggestion:
This option would make it possible to execute common code which is needed on every or almost every event, or to execute common code e.g. on any userevent. A filter option would be neede here to be able to filter events on which the common code should not be executed, e.g. to only use this option on userevents.
With best regards
AP
