The current behavior of the ""Array Max and Min PtByPt" library VI is to return only the FIRST occurrence of an element in the input array that is the minimum or maximum value. If the array contains data for which each element is unique, that's fine. But if the data is NOT unique, and more than one element can contain the same value, this routine could provide considerably more functionality by returning ALL min/max element indices.This is in fact the current behavior of the "Array Max and Min" library VI.
I'd like to see the "Array Max and Min PtByPt" library VI updated to match the behavior of the "Array Max and Min" fucntion, namely that instead of returning only the index of the first min/max element found, it would return arrays of indices for ALL max/min elements found.
The implementation of the functions that process arrays intact (like "Array Max and Min") and the functions that process 'arrays' point-by-point (like "Array Max and Min PtByPt") should be both consistent and factorially implemented. The decreased functionality of "Array Max and Min PtByPt" is inconsistent and unnecessary. The full implementation would make that routine much more useful.
All of the PtByPt routines should be evaluated to see if they are consistent with their array-processing counterparts.
