Technically, I suppose you could consider this a bug.
The situation is this:
Net result:
Perhaps there's some technique I'm missing, but this is causing our team a pretty significant loss in productivity. (Note that we have no issue with re-using the .lvbitx from RT host code, that works just fine - it's using an existing front panel in interactive mode that you can't do without recompiling it locally.)
Project Explorer:
Change the target IP address:
Now you have to recompile...
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
