| User | Kudos |
| 10 | |
| 6 | |
| 5 | |
| 3 | |
| 2 |
I've always thought it would be nice to be able to change one of the elements of a cluster dynamically. I think one of the toolkits out there has something like this but I imagine it would be more efficient to have this natively supported.
If it isn't clear, the string constant on the bottom is dictating which element in the cluster needs to be changed. The output would be a cluster of [0,{random number}].
Of course you'll probably need an error cluster coming out incase you try and wire in the wrong data type. Maybe something like the variant to data icon would be better
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
