Jan_HeG
Double clicking a terminal will add the control or indicator
Status: Declined
National Instruments will not be implementing this idea. In LabVIEW 2019 and later, the 'Create' menu options for terminals are always available at the top of the right-click menu, making them much more efficient to select.
I know that I am fresh on these forums, and have only used LabView professionally the last half year, but nothing like this came up when searching, so perhaps it is is an idea worth mentioning:
Currently in labview: If we want to create a control from the terminal of a subvi or function we now have to left click -> create -> control. This action in itself require several seconds and very often a misclick produces an indicator or constant instead.  (move mouse, select it, delete it, back to the terminal, left click, create, control)
My idea: Double clicking a terminal has today no useful action linked to it - so my idea is that when double clicking an input terminal a linked control will be created, and when double clicking an output terminal a linked indicator will be created.
Crtl + double click could create a constant: linked when clicking on a input, floating when clicking an output
Ctrl+double click could also create a floating constant when used on wires 😉
2 Comments
Matthew_Kelton
There is one problem with this - double-clicking opens the subVI.  If you have a full connector pane, you have no way to quickly open the subVI.  I would much prefer to loose a little time once when I need to create a control or indicator than the time I would lose everytime I wanted to open the subVI.
Darren
Proven Zealot
Status changed to: Declined
