michael.wagner
Disable Run-Time Shortcut Menu
Status: New
There is no way how to programatically disable the Run-Time Shortcut Menu with a property node.
The only way is to work with event structures what is quite unhandy:
https://forums.ni.com/t5/Example-Program-Drafts/Disable-Right-Click-menu/ta-p/3500824
2 Comments
daniel_rudaz
You can put a Property Node
Select class VI (VI server->VI->VI)
Select Front Panel Window -> Allow Runtime PopUp
It acts like the menu VI property, Window Apparence, Customize, Allow default run-time shortcut menus.
Enrico_Segre
but this affects the whole FP and not atomically to the control.
