| User | Kudos |
| 10 | |
| 6 | |
| 5 | |
| 3 | |
| 2 |
Hi all,
when I use breakpoints for debugging, I found that the breakpoints sometimes automatical re-appear after they are deleted from the breakpoint manager. I did some tests and found that they only appear again, when there is no other change in that VI, so the VI is not marked with the * in the title, which indicates unsaved changes. They will also not reappear when the VI is saved manually after the breakpoint is deleted.
So the suggestion is that a VI should also be marked as unsaved after deleting a breakpoint.
Regards, Patrick
The described behavior is a bug, but I need a reproducible case to file it.
