| Usuário | Contagem |
| 4 | |
| 4 | |
| 3 | |
| 2 | |
| 2 |
I often need to count how many times a condition is verified inside a loop. The simplest way to do so is:
What about this?
The "conditional terminal" should be enabled by right clicking on the operator, and may apply to every VI with 1-1 I/O pattern.
Of course it performs the operation in case of "TRUE", and leaves its input value unchanged in case of "FALSE"
Você deve ser um usuário registrado para adicionar um comentário aqui. Se você já estiver registrado, faça logon. Se você ainda não estiver registrado, registre-se e faça logon.
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
