Modify the default behavior of modal VIs to preclude them from becoming modal until the VI is actually executing, as opposed to the current behavior of becoming modal as soon as the vi is reserved for execution.
This prevents modal front panels that are left open during debugging from jumping to the front as soon as the top level calling VI is run, necessitating workarounds like killing LabVIEW via the task manager, the use of custom "Abort" VIs, or setting the modal property programmatically.
This idea is essentially a mutation of this one: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/New-option-for-window-modality/idi-p/2598027
