User | Kudos |
6 | |
3 | |
3 | |
2 | |
2 |
I'd like to suggest that the clean up tool behave the same for loop iteration and conditional terminals as it does for other block diagram objects. I frequently end up with a little jog between an item and the conditional terminal. I like that there is an attempt to move the terminals to their corresponding default corners, but they ought to have the same spacing from the loop frame as they do by default.
