User | Kudos |
18 | |
6 | |
4 | |
4 | |
4 |
Hi all,
We need a better way to insert a node in a wire without breaking the wire. Right now, if we put the mouse cursor a little bit below the wire, right-click, insert, select the node that you want to insert, and insert, we can insert the node without breaking the wire, but this current method has too many steps. What if I already have the node on my block diagram and I just want to copy that node and insert it in a wire without going through the pallatte?
It will be nice when I move my node while holding down shift+control and the node overlap a wire, the wire will just connect the the node automatically.
Yik
Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
