| User | Kudos |
| 1 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
Instead of the two step process of wiring an input on the Connector Pane and then changing the terminal setting to Required through the right-click menu, holding down the Ctrl key while wiring the input will automatically set the terminal to Required.
I know there's a LabVIEW option to set all terminals to Required as default, but I usually use a mix of Required, Recommended and Optional.
While I acknowledge the need to configure the connection faster, the proposed use of the Ctrl key would be confusing because of the "switcheroo" behavior.
