 Ken_Brey
			 on
		03-31-2013
		07:42 PM
			2 Comments (2 New)
			Ken_Brey
			 on
		03-31-2013
		07:42 PM
			2 Comments (2 New)
		If I right-click with the wiring tool on an output terminal and select a new item from the palette, LabView should assume that I would like to wire that new item to the place where I right-clicked. If the item I selected has only one type-compatible input to the output I originally right-clicked, it should automatically make that wire connection when the new item is dropped. Similarly, if I right-click on an input and select an item from the pallet, if there is only one compatable output on the item I selected, LabView should go ahead and wire that up when I drop the item.
Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
