User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
When wiring to a growable node that is currently full requires you to either pull the node bigger first and then wire or wire and create a wire stub, then pull it larger and the Connect the stub to the terminal.
Instead change the behavior so, if wiring is started and ends over a growable node, the node will grow automatically and add the wire being created to the new terminal.
For example: starting an error wire and ending on a merge that is currently full, the node automagically grows by one and adds the wire to the new (last) terminal.
Chief LabVIEW Architect, Testeract | Owner, Q Software Innovations, LLC (QSI)
Director, GCentral | Admin, LabVIEW Wiki | Creator, The QControl Toolkit
Certified LabVIEW Architect | LabVIEW Champion | NI Alliance Partner
