| User | Kudos |
| 2 | |
| 2 | |
| 2 | |
| 2 | |
| 2 |
I am extensively using the Array to Spreadsheet string Primitive and most of the time I never used the Format string input (Use to wire an empty string constant) and still I am getting the right result what I expect. So I think it would be better if the Required Terminal is changed to an Optional Terminal.
It is known that the Array to Spreadsheet string is Polymorphic, but when we wire an array of I32 and DBL the output string is DBL format only. It would be good if the output String adapts the data type that is wired unless otherwise specified by the Format string.
