| User | Kudos |
| 12 | |
| 12 | |
| 9 | |
| 9 | |
| 5 |
Application builder should output an errormessage when building an app from a vi, which uses property nodes, that are not available in LV runtime engine.
I have made a little test and have found out that the app is just build and in the app default values of the corresponding datatype is output from a property node without availability in runtime engine. I would expect an errormessage during app build, or at least during runtime of the app. I have performed this test with LabView2009SP1, because I have just got the 2010SP1 DevSuite version some days ago and have not installed it yet, because I use the SP versions only, you will guess why ... 😉
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
