Any idea that has received less than 8 kudos within 8 years after posting will be automatically declined.
I like the glyphs in the project explorer window that indicate the scope of each vi. I would find it extremely helpful if glyphs were added to indicate a VI's override status. (Must override, overrideable - normal dynamic dispatching, and not overridable - static dispatching)
> It would be nice if we could change these
settings from the Project Explorer
> context menu, just like how we can
change Scope from the context menu.
Out of curiosity...
we've been deliberately avoiding loading up the pop up menus with a lot of noise, and given all the item settings that are becomming possible, it could be a lot of noise when you pop up on any VI owned by a library, but especially the specialized libraries (xctl, lvclass). Is that a direction you'd want us to trend? Have we been too conservative in what we create pop ups for?
> It's a 16x16 icon. We're essentially out of space to represent any furhter information in the icon. Any proposals?
Actually, when you include the access scope key the icon area is 16x20. There is room under the key for arrows to indicate inheritance.
The arrow pointing up indicates this vi overrides a parent vi. The arrow pointing down indicates this vi can be overriden in child classes. Red for must inherit; green for may inherit. Of course, I don't see any reason why the main part of the icon can't be obscured a bit if you wanted to do something a bit nicer. Something like the Windows shortcut glyph in the upper left and lower left corners wouldn't prevent users from being able to see that there's still an object block under there.
As one who dislikes large or deeply nested pop up menus, I think this would be a worthwhile addition.
I agree, today I worked overriding some VI (LV2011) and could be very helpful if I know wich methods are mandatory to override and wich vi's are overrided vi's by icon on the project explorer.
