User | Kudos |
18 | |
5 | |
4 | |
4 | |
4 |
There should be an option to fully enable optimization when building an application as to automatically remove performance impacts caused by diagram elements that shouldn't cause any.
As summarily declined by NI, this idea
shows that unless you manually go over ALL your VIs disabling debugging, Diagram Disables (that are supposed to not avoid executing some code!) you'll suffer a performance impact.
It is preposterous to expect the users to manually disable/reenable debugging on every single VI when building an application.
Please add an option to enable full optimization.
