About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Top Kudoed Authors
Add a symbol to a string control or constant to detail its display format
When a string control, indicator or constant is switched from any mode other than Normal Text, display a small glyph (similar to the radix indicator on numeric controls) to allow you to see that the display is something other than Normal Text.
3 Comments
Knight of NI
Then you might want to go here http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Indicate-the-display-format-of-Strings/idi-p/917203#A1 and kudo that idea, which Altenbach had already proposed.Smiley Wink
Message Edited by Ravens Fan on 10-13-2009 09:21 AM
Knight of NI
This feature is in development, thanks to Altenbach.
Great suggestion nonetheless.  Smiley Happy
______________________________________________________________________
Status changed to: Duplicate
