LabVIEW APIs Discussions
Scripting with polymorphic VIs
I don't see it there either!
Generic | GObject | ???
Message 11 of 13
(2,595 Views)
Above Generic there is a VI class, under that is Polymorphic VI.  On a new blank BD press CTRL+Shift+B to bring up the class browser, from there you can browse classes, find properties and create them.
Message 12 of 13
(2,595 Views)
I got it!  When you create a new VI with scripting, you have to create a constant on the "Type Specifier VI RefNum" terminal and configure it for a polymorphic.  Otherwise the polymorphic specific options do not show up as valid property nodes.
NOTE: This is regardless of whether or not you select "Polymorphic VI" for the VI Type terminal...
Thanks for all the help!!!
Message 13 of 13
(2,595 Views)
