LabVIEW APIs Discussions
Scripting with polymorphic VIs
I'm trying to programmatically add VIs to a polymorphic VI but cannot find any method or property that would let me do that.
I would expect there to be a property that contains children of the polymorphic VI and a method to add VIs to it, but cannot find anything like that. I would also like to set the short and long names of the VIs in the polymorphic VI as well, since that is a tedious job that is very error prone when doing manually.
Can anyone show me how that can be done?
Thanks a lot!!
Joseph
Message 1 of 13
(12,601 Views)
Not sure it has exactly what you want but take a look at this example on LAVAcr.
Hope this helps
Epictetus
Antoine Chalons
Message 2 of 13
(9,020 Views)
Merci beaucoup!! C'est ce qu'il me faut pour commencer.
Thanks! That's what I needed to start with.
Message 3 of 13
(9,020 Views)
I can now add VIs to a polymorphic VI.
Is there a way to change the properties of the polymorphic VI (adapt to type, show selector, which icon to show...)?
Can I change the selector name of each VI contained in a polymorphic VI?
The link from lavacr does not do these things.
Thanks!
Joseph
Message 4 of 13
(9,020 Views)
You need to activate scripting and make sure you have a polymorphic VI type reference, if you activate that you get the following properties:
InstanceInfo will show the information about every VI.
Ton
My LabVIEW Ideas
Message 5 of 13
(9,020 Views)
Hey,
thanks a lot. Those were the properties I was looking for. I used InstanceInfo as write node and added the paths with selector and menu names. It worked like a charm, and it's easier to manipulate than the previous solution.
Joseph
Message 6 of 13
(9,020 Views)
TCPlomp,
I can't seem to find the AdaptToInputs using LabView 2014.  It might have something to do with selecting the polymorphic VI type reference?  Any thoughts?
THANKS!!!
Message 7 of 13
(9,020 Views)
Here's a 2014 snippet.  You do need to have the PolymorphicVI class not just VI.
Message 8 of 13
(9,020 Views)
How do I find it (How do I drop that onto the block diagram)?  When I connect a property node to the "new VI" scripting command I can't find PolymorphicVI as an option.
Is it considered on object of a Polymorphic VI?
Thanks!
Message 9 of 13
(9,020 Views)
You need to cast the object (use To More Specific Class) to a PolymorphicVI.
Message 10 of 13
(9,020 Views)
