03-17-2009 11:27 PM
Hi All,
We want to control Votsch VT 7004 Termal chamber using RS232
Is anyone has the VI's to control this instrument
could you suggest a way to control this through labview
03-20-2009 04:08 AM
I just finished this VI for my project (it control the VTM 7004 over RS232). You should also set some parameters on the chamber's MINCONTROL : ASCII-1, BUS 1, BAUD rate 19200.
I hope this will help you.
03-20-2009 07:16 AM
Hi
Thanks for the help
I tried with this vi's but it seems no communication is going on
i have few doubts
1) is the DB9-DB25 cable i made, for connecting chamber to pc, is correct? (i am attaching fig)
2) is there any difference between VTM 7004 and VT 7004
3) in manual it is given that ascii programming we have to send $<chamber address><command><CR> through rs-232 to get response from the chamber
but i think you are sending some other format
Pradeep
03-20-2009 08:46 AM
03-20-2009 09:07 AM - edited 03-20-2009 09:10 AM
Hi
Problem is VT 7004 has RS232 with DB25 pin connector, so we used DB9-DB25 connector
please find attached file P101-108.pdf
last two pages contain Protocol in ASCII Fromat
could you suggest how to implement it
Thanks in advance
Pradeep
03-24-2009 11:23 PM
Hi
I have Modfied Votsch_cks_outputfromatting.vi as follows
STX as $, chamber address to 00, ETX as <CR> as in the ASCII protocol
but i was not able to see any response from the chamber
could you suggest whether i am correct or not
Pradeep
03-31-2009 05:19 AM
Hi
Please find the attached file for ascii protocol format for VT 7004
could anyone suggest how to proceed
Pradeep
03-31-2010 12:06 AM
Hello All,
I have newly registered in this forum,
and i am very new to this topic also,
I wish to conrol Votsch VT 7004 (Thermal chamber) through LabView 8.6 and i have a serial interfacing RS232 (DB9)to communicate with the VT 7004(DB25). I am sending ASCII format data ( mentioned in it's data sheets) just to observe whether it is responding or not ( these VI 's i got from this forum only). no response from VT 7004. i don't have ample Data for the VT 7004 Automation tests. Anyone please help me how to communicate with this VT 7004.
Thanks in advance
