cDAQ-9139 can I directly get access to installed c-module in the 9139 from another external computer?
I have software that I has to run on a 64bit computer. The cDAQ is 32bit computer and won't run the software needed.. the software is designed to run on NI-9181 single chassis with NI-9234 module but the 9139 is already available.
(2,421 Views)
Hi ChuckV,
What is the software that requires 64 bit?
Additionally, you may get better viability on the Multifunction DAQ Forum.
All the Best,
Noah B.
Applications Engineer
http://www.ni.com/support
Noah B.
Technical Support Engineering
(2,400 Views)
