programing agilent E5062A with external controller
Hello ,
I am looking for a solution to agilent E5062A program to load a .sta file
I already use the command: MMEM: LOAD an error occurs invalid separator please help
(3,157 Views)
It looks like your SCPI command isn't properly formatted...but you didn't post the code so can't be absolutely sure.
On instruments I use the SCPI command to load a saved config file is something like...
MMEM:LOAD 'filename';
Note, there's no space between ":" and LOAD.  But I've had issues on some instruments with the filename string. Make sure you use the ' quotes.  Consult the manual for more details on file paths.
Craig
(3,133 Views)
I use the following python code but an error :error separator
import Gpib
inst=Gpib.Gpib(0,16)
inst.write(":MMEM:LOAD ""USER(D)/state.sta""")
(3,105 Views)
Stil no luck?  Try..
inst.write(":MMEM:LOAD 'USER(D)/state.sta';")  - Note changed parentheses and the ; at the end.  Probably a termination char also (\r or \n or \r\n) but I don't know how those are handled in python these days.
Some older Agilent instruments didn't support spaces in filename and there may be a maximum filename length that's shorter than the Windows standards.  So try names that fit the old DOS 8.3 format  (abcdefgh.dat).
Craig
(3,097 Views)
Remember that if multiple files begin with the same 8 characters in the DOS 8.3 format, then you will need to see which order they are alphanumerically and add a ~ followed by a single digit to the first 6 characters.  (abcdef~2.dat) for the second file in alphanumeric order.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,093 Views)
