Labview programming Kepco power supply by RS-485 bus
Kepco KLN is programmingable power supply, can use RS-232/RS-485 to communication. detail see product manual.
LabVIEW very easy to control it. use VISA function to serial port communication. Should configure computer and power supply both side.
Message 1 of 10
(2,960 Views)
And your question is?
Santhosh
Soliton Technologies
Message 2 of 10
(2,945 Views)
This is an example only.
Message 3 of 10
(2,888 Views)
But no source code, just an image?
Why not share the VI to help others?
Message 4 of 10
(2,864 Views)
Some example code would be helpful as a time saver!
Message 5 of 10
(2,725 Views)
I see this as an advertisement for that power supply 🤔
Kees
Message 6 of 10
(2,710 Views)
I was able to create a Labview program  to control the KLN40-19 via Ethernet or RS485.
I can provide EXE to you so you can test it
Message 7 of 10
(1,000 Views)
What does your EXE provide above what users can get from this site https://www.kepcopower.com/drivers/drivers-dl3.htm#epics?
Most people here are programmers. They would not be interested in an EXE but the actual source code. If you are not willing to provide the actual source code, there will be very little interest in your offering. And a driver in source code for that device can be found on above page.
Rolf Kalbermatter  My Blog
Message 8 of 10
(983 Views)
I tried to upload the project and the main VI to the thread but an error message came up Sorry Unable to complete the action you requested.
I am not a full time LabVIEW programmer and am sure there are many improvements that can be made.
How can I upload the files . Should I upload the project and VI?
Message 9 of 10
(969 Views)
