Labview programming Kepco power supply by RS-485 bus
Kepco KLN is programmingable power supply, can use RS-232/RS-485 to communication. detail see product manual.
LabVIEW very easy to control it. use VISA function to serial port communication. Should configure computer and power supply both side.
Message 1 of 10
(3,079 Views)
And your question is?
Santhosh
Soliton Technologies
Only two ways to appreciate someone who spent their free time to reply/answer your question - give them Kudos or mark their reply as the answer/solution
Message 2 of 10
(3,064 Views)
This is an example only.
Message 3 of 10
(3,007 Views)
But no source code, just an image?
Why not share the VI to help others?
Message 4 of 10
(2,983 Views)
Some example code would be helpful as a time saver!
Message 5 of 10
(2,844 Views)
I see this as an advertisement for that power supply 🤔
Kees
Message 6 of 10
(2,829 Views)
I was able to create a Labview program  to control the KLN40-19 via Ethernet or RS485.
I can provide EXE to you so you can test it
Message 7 of 10
(1,119 Views)
What does your EXE provide above what users can get from this site https://www.kepcopower.com/drivers/drivers-dl3.htm#epics?
Most people here are programmers. They would not be interested in an EXE but the actual source code. If you are not willing to provide the actual source code, there will be very little interest in your offering. And a driver in source code for that device can be found on above page.
Rolf Kalbermatter  My Blog
Message 8 of 10
(1,102 Views)
I tried to upload the project and the main VI to the thread but an error message came up Sorry Unable to complete the action you requested.
I am not a full time LabVIEW programmer and am sure there are many improvements that can be made.
How can I upload the files . Should I upload the project and VI?
Message 9 of 10
(1,088 Views)
