在 04-14-2022 01:17 PM
Kepco KLN is programmingable power supply, can use RS-232/RS-485 to communication. detail see product manual.
LabVIEW very easy to control it. use VISA function to serial port communication. Should configure computer and power supply both side.
And your question is?
在 05-19-2022 11:37 AM
This is an example only.
Some example code would be helpful as a time saver!
I see this as an advertisement for that power supply 🤔
Kees
在 07-07-2025 10:55 AM
I was able to create a Labview program to control the KLN40-19 via Ethernet or RS485.
I can provide EXE to you so you can test it
What does your EXE provide above what users can get from this site https://www.kepcopower.com/drivers/drivers-dl3.htm#epics?
Most people here are programmers. They would not be interested in an EXE but the actual source code. If you are not willing to provide the actual source code, there will be very little interest in your offering. And a driver in source code for that device can be found on above page.
在 07-08-2025 08:15 AM
I tried to upload the project and the main VI to the thread but an error message came up Sorry Unable to complete the action you requested.
I am not a full time LabVIEW programmer and am sure there are many improvements that can be made.
How can I upload the files . Should I upload the project and VI?
在 07-08-2025 08:19 AM
upload successful
