Adam 5000/485 Drivers Required
I have tried to find drivers for the Advantech Adam 5000/485 serial device.
I know that I could send ascii code using Visa but just want to save some time if someone has already done it.
Message 1 of 17
(5,930 Views)
Hi Andy Try Hard,
I have looked around and found these links:
http://forums.ni.com/ni/board/message?board.id=170&requireLogin=False&thread.id=154483
http://forums.ni.com/ni/board/message?board.id=170&message.id=233448&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=190&message.id=12&requireLogin=False
It seems as though there are no specific drivers. It may be worth contacting Advantech to see if they have any available.
Kind Regards,
Owen.S
Applications Engineer
Message 2 of 17
(5,904 Views)
HI,
Did you manage to find any drivers for the adam-5000-485 for labview? i am starting to use this software and i am unsure as to how to get the adam hardware to speak to labview. Any help would be greatly appreciated.
Message 3 of 17
(5,372 Views)
I didn't find any drivers for the Adams 500/485 so i created my own that just do want I wanted and are not very well documented and not comprehensive.
If you are interested I will look them out and post them.
Message 4 of 17
(5,365 Views)
that would be a great help, thank you very much.
Message 5 of 17
(5,362 Views)
Going through my old stuff I found that I only did vi's for digital i/o.
I am sure that it will give you a chance to see how they work and write your own vi's
good luck
Message 6 of 17
(5,360 Views)
thats great thanks for that, however i am running version 8.6.1 would you know if there is a way of converting to my earlier version? thanks again.
Message 7 of 17
(5,357 Views)
No sorry I don't know how to do that. however I am sure that all of the functions are available in Labview 8 and you should be able to copy what I have done.
Message 8 of 17
(5,349 Views)
Here is an 8.0 version
If you are gonna use these vi's make sure that the open and close section only are used in the beginning and ennd of your program.
So the first thing to do is to split read or write in 3 parts and from the other one only take the middle part.
good luck
Message 9 of 17
(5,342 Views)
the official conversion board is here:
http://forums.ni.com/t5/Version-Conversion/New-Conversion-Board/td-p/1836827
Message 10 of 17
(5,338 Views)
