 Andy Try Hard
			Andy Try Hard
			01-13-2010 01:57 PM
I have tried to find drivers for the Advantech Adam 5000/485 serial device.
I know that I could send ascii code using Visa but just want to save some time if someone has already done it.
01-15-2010 05:33 AM
Hi Andy Try Hard,
I have looked around and found these links:
http://forums.ni.com/ni/board/message?board.id=170&requireLogin=False&thread.id=154483
http://forums.ni.com/ni/board/message?board.id=170&message.id=233448&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=190&message.id=12&requireLogin=False
It seems as though there are no specific drivers. It may be worth contacting Advantech to see if they have any available.
Kind Regards,
 daveporter19
			daveporter19
			01-16-2012 03:46 AM
HI,
Did you manage to find any drivers for the adam-5000-485 for labview? i am starting to use this software and i am unsure as to how to get the adam hardware to speak to labview. Any help would be greatly appreciated.
 lizand
			lizand
			01-16-2012 09:05 AM
I didn't find any drivers for the Adams 500/485 so i created my own that just do want I wanted and are not very well documented and not comprehensive.
If you are interested I will look them out and post them.
 daveporter19
			daveporter19
			01-16-2012 09:25 AM
that would be a great help, thank you very much.
 lizand
			lizand
			01-16-2012 09:48 AM
Going through my old stuff I found that I only did vi's for digital i/o.
I am sure that it will give you a chance to see how they work and write your own vi's
good luck
 daveporter19
			daveporter19
			01-16-2012 10:06 AM
thats great thanks for that, however i am running version 8.6.1 would you know if there is a way of converting to my earlier version? thanks again.
 lizand
			lizand
			01-17-2012 01:49 AM
No sorry I don't know how to do that. however I am sure that all of the functions are available in Labview 8 and you should be able to copy what I have done.
 Albert.Geven
			Albert.Geven
			01-17-2012 01:45 PM
Here is an 8.0 version
If you are gonna use these vi's make sure that the open and close section only are used in the beginning and ennd of your program.
So the first thing to do is to split read or write in 3 parts and from the other one only take the middle part.
good luck
 Albert.Geven
			Albert.Geven
			01-17-2012 02:03 PM
the official conversion board is here:
http://forums.ni.com/t5/Version-Conversion/New-Conversion-Board/td-p/1836827
