Hobbyist Toolkit
Is or will LabVIEW Hobbyist Toolkit supported with Raspberry Pi 5?
I was reading some of the articles available on LabVIEW Hobbyist Toolkit, such as Using Raspberry Pi or Arduino with LabVIEW - NI . I'm curious if the toolkit is going to be supported with RPi5. Thanks!
(1,678 Views)
Hi
I assume you want the status of this software.
RP 5
Hobbyist 2024 Q3 ( and Q1 Patch 1 ) installs and works flawlessly. Older versions does not.
RP 2 B
I cannot make the Target Configuration work with LINX as found in VIPM together with any LabVIEW version before 2020. Nor with Hobbyist 2020 and newer. Cannot complete uploading a firmware image. Useless. Worked in the past. So something changed. Probably the server access.
RP 2 B
Using one of the pre-configured Raspberry Pi and LabVIEW images ( beta concept ) for 2021 or 2022 works flawlessly. And Target Configuration then also works so that you can change from 2021 to 2022 or vice versa. TC may also work with 2020 or 2023 or later, but I haven't tried that. See :
https://forums.ni.com/t5/LabVIEW/Linx-install-on-a-Raspberry-pi-3B/td-p/4286669
The only downside to this is that the Raspberry Pi OS chosen is the GUI-less 'Lite' version.
Regards
(1,614 Views)
