Hobbyist Toolkit
Device interrogation failed: unable to connect to the target
Fresh PC worked with no problem
Did get a crash when I closed it down though.
Have now removed all traces of Labview, including Silverlight, Rabbit & Erlang from the desktop- Will see what happens
Message 11 of 20
(5,441 Views)
Ok, so uninstalling everything from the Desktop PC still didn't work - At least I now have a working system to compare with & I know what the problem is - I just don't know how to "Downgrade Visa 21.5 to Visa 20.0 - I guess more research is required'
Message 12 of 20
(5,430 Views)
That is removed if you uninstall everything.  Or you should be able to uninstall just VISA.  You do that through NI Package Manager.
David Wilt
The New Standard LLC
Message 13 of 20
(5,424 Views)
Visa is not an option in NI Package Manager - I tried to delete the individual files, couldn't as they were open in NI-Max. Renamed them. Un-installed everything via NI Package Manager. Uninstalled NI Package Manager, then uninstalled National Instruments Software, Silverlight, Erlang OTP, RabbitMQ Server. Re-Installed Labview 2020. When I opened NI Max, it initially showed Visa as 21.5, but changed to 20.0 almost immediately. Now shows exactly the same as the laptop, but still won't connect?
This is really frustrating, but it looks like my only option is to format my Desktop PC
Message 14 of 20
(5,409 Views)
You do not see NI-VISA like this in NI Package Manager?  This is from LabVIEW Professional so it may be different if you are using a Community Edition.
The fact that MAX showed a different version initially proves that not everything was removed.  If everything had been removed it would not be able to know 21.5 was ever installed on the PC.
Unfortunately this has been my go to when wanting to remove all NI software from a system.
David Wilt
Message 15 of 20
(5,399 Views)
Accepted by Dumpit
The LINX target configuration vi connects to the RPI using ssh. If you are able to ssh to the RPI from puTTY then its possible your firewall settings are blocking the LabVIEW application.
Message 16 of 20
(5,394 Views)
Accepted by Dumpit
Thanks for the info - Not sure if it actually was the Firewall (Couldn't find anything) but it got me thinking. I removed everything I could think of (again) but this time, I went big - Also searched the registry for anything to do with National Instruments, Visa, PXI, and PAL. Deleted anything that had the letters ni in the string (Figured I'm going to have to format anyway) - Installed Labview 2020 Community Edition, and still couldn't connect. Was about to throw my toys, when I remembered your post - Checked the Firewall & couldn't see anything obvious.
I then decided to disable my Anti-Virus (Avast)
I'm In - Thanks so much.
Appreciate all the help.
Message 17 of 20
(5,359 Views)
So this has been fun - Successfully connected to Target, but Labview installation Failed. Wasn't really looking forward to starting a new thread. Saved the log file for it, but decided to fumble around with the Pi side of things first. Went to Raspberry Pi Imager & loaded the latest version, with recommended software. After setting up the Pi, Labview successfully connected, and I updated (Installed?) the software successfully. Thought I was finally done - Tried to run the example & the deployment completed with errors. Example VI would not run. So far I'm batting 3 out of 3 - Not sure what I did at this point, seeing as I had started playing with Avast Firewall rules & Bouncing between Labview & Pi. Bottom Line is that I am now able to run the example, with my anti virus active. (It's weird though, as the "fresh" laptop that I loaded, already had Avast installed & never gave me a single problem connecting) - I can only assume that I had the remote GPIO disabled on the Pi (No idea if this required to run the example, but it seems logical as Labview on the PC is controlling the output on the Pi) - Final Outcome is Labview 2020 Community Edition, Raspberry Pi Bullseye (2020) - After many attempts, is finally able to run the example with the Pi Config below.
Message 18 of 20
(5,343 Views)
Hi, I am facing the same issue as you did and currently looking for more help on it, would you mind if you could give me some help on fixing this error code?
Message 19 of 20
(3,641 Views)
The issue is that the current Raspberry Pi images ship with a newer OpenSSH that got rid of some cipher/key type options. (www.openssh.com/legacy.html) At least LabView 2020 only supports ssh-dss or ssh-rsa host keys.
I added the following lines to my /etc/sshd_config:
HostKey /etc/ssh/ssh_host_dsa_key
HostKeyAlgorithms +ssh-dss
Then I generated a DSA key with:
sudo ssh-keygen -t dsa -b 1024 -f /etc/ssh/ssh_host_dsa_key -h -C forlabview
The DSA algorithm is insecure/broken, but for my use case I it doesn’t really matter.
(There should theoretically be a “medium‑security” rsa key type that still works with this setup, but I couldn’t get it to work.)
Afterwards the connection succeeded.
Message 20 of 20
(1,494 Views)
