Feedback on NI Community
Problem with Signiture
I'm only able to get a max of three lines in my signiture. Is this a limit or just an early problem.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(3,992 Views)
Ed Dickens -
The signature is currently set to a maximum height of 48 pixels which is limiting you to three lines of text. From looking at your signature, it looks like you might want more like eight lines of text. I have reconfigured the system to allow 128 pixels which should give you plenty of room.
Thanks for the feedback,
Molly K.
Web Support & Operations Manager
(3,981 Views)
Thanks Molly,
That helps clean things up a bit.
Ed
(3,974 Views)
