Feedback on NI Community
New Features on the NI Discussion Forums!
Laura F. wrote:
Timmar,
The number in the top section of the Kudos icon will increment.  The whole page does not refresh.  One thing you might try is disabling "Enable Live Updates" in your Forum preferences.
Laura
Alas, No Success, Therefore no Kudos from me (only because I can't)
iTm - Senior Systems Engineer
uses: LABVIEW 2012 SP1 x86 on Windows 7 x64. cFP, cRIO, PXI-RT
Message 61 of 68
(4,063 Views)
The inability to give Kudos is not related to Firefox...  It is related to how your company blocks pop-ups, spyware, cookies, and other similar mechanisms, which includes giving Kudos.  I have the same problem at one particular customer site, using Internet Explorer 7.
R
Message 62 of 68
(3,928 Views)
I can give kudos with IE, but not firefox at work. Surely it would make no difference whichever client I am using?
_____________________________
- Cheers, Ed
Message 63 of 68
(3,922 Views)
That's true..  Hummm.... strange..  😮
Message 64 of 68
(3,916 Views)
Just installed Firefox (latest) since I was not able to give Kudos from the client site, and often could not send the reply.
I can now post, but still not give Kudos.  I suspect it is the pop-up blocker that prevents giving out Kudos..
Anyone seeing a similar issue?
R
Message 65 of 68
(3,883 Views)
I just tested kudos on your post above. I am using firefox 3.0.5 at home, This is a standard install of firefox with no add ons. FF inbuilt popup blocker is enabled.
I have exactly the same setup on my pc at work, the only difference I can think of is that it is behind the firewall. I can;t post kudos in FFat work, but I can in IE
This is really bizare, but at least it's not just me, eh
- Cheers, Ed
Message 66 of 68
(3,877 Views)
I am now using the same version 3.0.5.  I just tried to give you a Kudos, but it kicked my to the first post of this thread instead..  😮
At least I can post...  IE just dies and tells me that there is a virus on the webpage..  << talk about strange >>
Message 67 of 68
(3,868 Views)
an Update to this thread...
actually, Laura's suggestion to disable (remove checkmark) for "Turn on Live Edits and Updates" worked.
Message 68 of 68
(2,995 Views)
