10-06-2009 08:05 AM
... and makes it impossible to add Tags.
It does not happen on all threads. I just happened to catch another one this morning, where I wanted to add a tag.
Check out this thread: http://forums.ni.com/ni/board/message?board.id=180&message.id=3706
Solved! Go to Solution.
10-06-2009 09:07 AM
10-06-2009 11:29 AM
Thanks Mathan,
It worked 😄
Curious: how did you know?
10-06-2009 11:39 AM
I CAN GIVE KUDOS!!!
Wow.. That was my problem!! Thanks and Kudos to you Mathan! 😄
10-06-2009 01:29 PM
Hi Ray -
Glad to hear that Kudos are working now! I thought you had one computer where Kudos worked and one where it did not so I assumed it was a problem with a particular computer. Sounds like that was an incorrect assumption on my part and I apologize for not catching that earlier when you reported it. Have fun giving out kudos!
Laura
10-06-2009 01:44 PM
Thanks Laura.
Don't worry about it since my suspicions were the firewall at this location. I would never have thought that a setting could cause the issue.
At least if others have a similar problem we can suggest a solution. 🙂
Have fun!
RayR
10-06-2009 10:20 PM
Ray.R wrote:Thanks Mathan,
It worked 😄
Glad it worked. ![]()
Actually i pirated this idea from Laura.
See her post (#60). Hope Laura will never blame me for this. ![]()
