Feedback on NI Community
NEW images only! Do not reply.
Message Edited by Ben on 01-28-2007 01:41 PM
Message 21 of 89
(9,268 Views)
Message Edited by Ben on 01-28-2007 01:46 PM
Message 22 of 89
(9,267 Views)
Message Edited by Ben on 01-28-2007 02:06 PM
Message 23 of 89
(9,264 Views)
Creating an array of Occurrences Occurrences are an elegant way of implementing a Boolean event based architecture. An example of Occurrence Based Architecture (OBA) that recently came to mind after I viewed a copy of one of the Animusic videos.
Message Edited by Ben on 01-28-2007 02:17 PM
Message 24 of 89
(9,257 Views)
Message Edited by Ben on 01-28-2007 02:20 PM
Message 25 of 89
(9,292 Views)
Message Edited by Ben on 01-28-2007 04:19 PM
Message Edited by Ben on 01-28-2007 04:20 PM
Message Edited by Ben on 01-28-2007 04:21 PM
Message 26 of 89
(9,238 Views)
Ben, Do I sense a nugget cooking? Smiley Wink
Here's a suggestion which might help making it cleaner, if you're feeling up to it.
Grab all of those images again, but save them in PNG format (will get rid of the annoying noise JPEG creates around text) and remove the scrollbars and toolbars from the images, as they create a lot of noise. If you want, Paint can save your images as PNG, or (even better), you can use the Code Capture Tool, which will grab only the image of the code you select. Place it in the LabVIEW\Project folder, restart and it will be in your Tools menu, just waiting to be used.
___________________
Try to take over the world!
Message 27 of 89
(9,216 Views)
Which I had read tst's post before saving everything to jpg.
Image to show outputs wired to the left.
Message 28 of 89
(9,203 Views)
___________________
Message 29 of 89
(9,165 Views)
Message 30 of 89
(9,167 Views)
