Feedback on NI Community
annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Is it still possible to view who gave Kudos?
Résolu !
Accéder à la solution
In the past you could right click on the number in the kudos box and pick an option to see who gave the kudos.  I know the sweet spot for doing this was kind of small and not quite where you might expect it to be.
Today I wanted to  look at who gave kudos to an idea in the idea exchange, and I could not find the spot at all.  The shortcut menu that came up on a right click never showed the option no matter where I right clicked.  I went to a kudos box for a regular message in the LabVIEW forum to see who gave kudos, and once again I couldn't find the menu choice?
Was this option taken away?  Or is there something wrong with the HTML page that is downloaded and should show this box?
Even refreshing the page didn't help.
Message 1 sur 21
8 279 Visites
I don't think it even required a right-click, you could simply click anywhere on the number to view the Kudos'ers.  Whatever the method, it is all busted now, probably related to the "upgrade" that messed up the recent Kudos widgets as well.
0 Compliments
Message 2 sur 21
8 274 Visites
Broke for me as well.
I gnearlly check that to see who I owe. Now I have to piece it back together, complicated by not being around for a while.
Please fix.
Ben
0 Compliments
Message 3 sur 21
8 264 Visites
It definitely was not removed on purpose. And it just occurred last night because I used this functionality yesterday.
I am checking on this.
Laura
Message 4 sur 21
8 249 Visites
I wonder if it is related to some of the comments in this thread.  http://forums.ni.com/t5/Feedback-on-NI-Discussion-Forums/No-Recent-Posts/td-p/1643960
0 Compliments
Message 5 sur 21
8 236 Visites
Worse!
I can't un-Kudos Bill's post at the top of the thread.  Guess you get to keep it!
I'm Blaming Laura - this started about the same time I got the PM about NI week with a long list of recipients- I had to delete it to clear the clutter overflowing from the PM section TO users column on my profile page.
Just kidding about blaming you - I know you'll get Li to fix it soon
"Should be" isn't "Is" -Jay
Message 6 sur 21
8 229 Visites
Not that I condone the behavior in this situation, but if you go to the options menu in the upper right corner of the message you can still revoke the kudos.
0 Compliments
Message 7 sur 21
8 219 Visites
I didn't see that choice in the Options menu.  I decided to Kudo Jeff's message, then tried to follow your instructions to unkudo it.  No option.
I guess Jeff gets to keep his Kudo's in a return of the favor! Smiley très heureux
0 Compliments
Message 8 sur 21
8 218 Visites
You have been kudoed and revoked.
Be sure to refresh the page in between.
0 Compliments
Message 9 sur 21
8 212 Visites
Surprised to see that I am a top tagger on the LV board now (and that Ben is not)....
0 Compliments
Message 10 sur 21
8 209 Visites
