Feedback on NI Community
取消
显示结果
搜索替代
您的意思是:
Icons thread
And here's a quick front panel example (Switch with LED: 5 seconds off, 0.5 seconds on).
21 条消息(共 498 条)
16,624 次查看
Please make a flashing execution highlight lightbulb for me!
Or better tell me how to quickly get into animated gif already
Jean-Pierre
LabVIEW, C'est LabVIEW
22 条消息(共 498 条)
16,612 次查看
Speaking of animation, take a look at this VI.
It's neat to see the animated icon on diagrams and hierarchy window.
One could make a tool to put a running/moving arrow on icons of VIs that are actually running in the hierachy.
23 条消息(共 498 条)
16,610 次查看
@tst wrote:
I'm hoping this post will come after the first post.
It didn't in my screen...
I'd better quote so you know what I'm talking about..
J
24 条消息(共 498 条)
16,583 次查看
Jean-Pierre,
I'm not quite sure what you had in mind, but here's a first draft. (It is only 800 bytes).
I am using Corel Photopaint, but there are probably better programs to do this. Corel is not very easy to use unless you are quite familiar.
p.s. I like your icon.vi, but prefer a 33 rotation instead of 32. 🙂
25 条消息(共 498 条)
16,624 次查看
Hi tst,
The trouble is that blue reply link isn't on the screen unless you are somewhere near the top of the screen. Maybe the blue reply link should be added with the black one.
Regards
Ray Farmer
Regards
Ray Farmer
26 条消息(共 498 条)
16,552 次查看
I've only just worked how to do static ones......
Regards
Ray Farmer
27 条消息(共 498 条)
16,600 次查看
I wanted to point out that Johnner has a cool animated icon now and just in case he decides to stop using it, here's the incriminating evidence - . Now, where did he get that idea?
Initially, I actually posted a much smaller file, but since I couldn't manage to get it work (presumably the lowercase problem) I ended up posting this one instead (which is actually a nice feature of the edit option).
I will see if I can do something with animation. My current version of Photoshop (5 Limited) can't do animated gifs, so I'll have to find where I put GIMP and brush up on it a little. Hopefully it can handle it.
___________________
Try to take over the world!
28 条消息(共 498 条)
16,633 次查看
Does anyone know if the animated Gifs work in LV 6.1? If so, can someone post JP's VI so that I (Lowly mortal with LV 6.1) can have a look.........
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
29 条消息(共 498 条)
16,581 次查看
I just tried.
Jp's VI uses the Get\Set VI Icon from image data methods, which don't appear to be available in 6.1.
It is a cool one though (it doesn't do animated gifs). Maybe you should consider upgrading, now that you have what to look for...
___________________
0 项奖励
30 条消息(共 498 条)
16,576 次查看
