07-01-2005 09:30 AM - modifié 07-01-2005 09:30 AM
Message Edited by Ben on 07-01-2005 09:31 AM
le 07-01-2005 09:50 AM
le 07-01-2005 09:59 AM
le 07-01-2005 10:11 AM
tst -
You are so efficient!
I will pass along your feedback about the images and the attachments, but I'm not sure when they will be able to redesign those pieces to accommodate these requests.
I wasn't able to reproduce the dual window issue. Can anyone else?
le 07-01-2005 10:18 AM
le 07-01-2005 10:25 AM
Also, it seems there is some problem with editing, I just tried to edit that post and the text didn't appear (maybe that also happens only when the page fully loads)? Addition: I just checked and that is the case. The text only appears when the page fully loads.
I wanted to edit to say that this doesn't actually have anything to do with the 2 windows, that was just a distraction.
What does have to do with 2 windows is that when you open 2 reply windows at the same time, the second one pops to the front and steals focus while you're typing. Admittedly, most people probably don't have 2 windows open at the same time, but I do (connection speed, remember?).
It looks like Ben won't be needing that HTML course after all...
le 07-01-2005 10:49 AM
Works all nicely for me so far.
Some random points I noticed:
le 07-01-2005 11:25 AM
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.le 07-01-2005 01:39 PM
Molly,
I like the new editing tool.
I especially like the ability to view the discussion in a popup. I find myself often opening two windows so that I can go between the discussion and my post.
Everything appears to be straight forward, and I've even found that local images can be attached by simply typing the local path instead of the URL address.
Now if you could just get that problem with the attachment being lost fixed!![]()
le 07-02-2005 12:52 PM
