FIRST Robotics Competition Discussions
Using A Mark I FRC 8 Slot cRIO Without FRC Image
Hi, I am a member of FRC robotics team 3451, and was hoping for some help.  We have two FRC 8 Slot cRIO devices, that we would like to put to use in our pre-engineering class.  However, we want to be able to use that hardware like it would be in industry.  That being said, what are the steps we would need to go about to create a labview program, that can interface with the NI 9201, NI 9403, and NI 9472, and then build and deploy it to the cRIO? Any help would be appreciated, and thanks in advance.
(6,929 Views)
To do this you would need LabVIEW FPGA installed and licensed in your pre-engineering lab. You would then write and deploy an FPGA VI that uses IO Nodes to expose the I/O of those modules to the main VI's front panel. You can then access the FPGA from panel from a LabVIEW RT application using the FPGA Host Interface VIs in the RT palette.
(5,089 Views)
Do you know if the FPGA add-in is included in the labview for frc package? If not is there a student license we can get for the package. Thank you!
(5,089 Views)
It is not part of the FRC software.
I know there are acedemic site licenses for FPGA. That's what would be appropriate for your lab. Student licenses are for student-owned computers.
(5,089 Views)
They're probably better off working with the site license for the RT Module versus the FPGA Module.  For something that would be in a pre-engineering lab, I'd expect they'd want to work with the Scan Engine and make codes in the RT code that interface with the I/O and let the scan engine abstract away how the I/O is grabbed.  Using the FPGA to work with the I/O is more for if they want to process the I/O on the FPGA itself.
The lab computers will need the following to work with cRIOs:
The compatible LabVIEW RT Module
The compatible NI-RIO drivers
(Optional) The compatible LabVIEW FPGA Module
The compatible version generally is the same year as the LabVIEW version you have installed.
(5,089 Views)
