01-04-2015 01:31 AM
While playing around with the RoboRIO we got back in December, we somehow got it into an error state we can't get it out of.
The Status LED is flashing constantly, which the documents say is an "unrecoverable error". While we were indeed poking around a lot, I have no idea how we managed to mess up the safemode. We didn't try to edit the ramfs at all. Anyway, from what I understand, the bootloader can attempt to read a recovery image from a flash drive. Is there a recovery image available? If not, what should we do?
Luckily we have the one we got in the kit up and working, so definitely not going to mess that one up.
Solved! Go to Solution.
01-04-2015 05:05 PM
If you press and hold the RESET button, does your roboRIO go into Safe Mode? That should allow you to use the roboRIO Imaging Tool to work with the device.
01-04-2015 05:07 PM
Nope. No matter what I do, the status light starts blinking steadily. I'm under the impression this means that our safemode filesystem is some how corrupted.
01-05-2015 03:22 PM
I have a similar problem with our Roborio. The image update did not complete and the device began flashing the status light continuously (see attached screenshot). I used safe mode to retry, but the result is the same. The device web page does not respond.
01-05-2015 04:48 PM
I think you need to make a service request with and Application Engineer to get access to the recovery image and to get help with the process to recover. Call 866-511-6285.
01-05-2015 06:44 PM
01-06-2015 11:50 AM
Hi Walter,
We're available today from 1-7pm CST. We're looking into the issue and look forward to hearing from you.
01-06-2015 01:47 PM
01-06-2015 05:19 PM
Thank you for the screenshot, Walter. Are you able to put your roboRIO into SafeMode? You can do this by holding down the reset button for approximately 10 seconds.
jcreigh, have you called in to the NI support phone number? If not, we reccommend that you do since it is easier for us to help you troubleshoot over the phone. The number is: 866-511-6285.
01-06-2015 10:04 PM
