Example Code
LabVIEW Box Plots
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
The LabVIEW Code attached provides support for creating box plots and having multiple box plots presented on a single graph.
This code started with and improved code from these two examples:
-Creating Boxplots Using LabVIEW
-Boxplots and Stem-and-Leaf Displays
Front Panel:
Block Diagram:
Improvements from the previous verisons:
-Improved quartile calculation: Median and Quartile Calculator (Q1, Q2, Q3) using LabVIEW
-Made multiple box plot graphs work properly
-Added ability to change horizontal scale of plots (width per box)
-Added ability to choose plot color (instead of just black)
-Allows differently sized data arrays for each plot (by using an array of clusters)
Attached versions are in LabVIEW 2014, 2009 and 8.0 (using save for previous)
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
Comments
gnunesjr
on
Thank you!  Extremely nice.  Works perfectly right out of the box, and is easy to use.
Just_Amber
on
This is amazing. Thank you for creating it.
sjtuyans
on
Thank you Craig, very easy to use and nice tool.
Shu Yan
CLA since 2010 | CTA since 2012 | CLED since 2016
sjtuyan@gmail.com
-Newton-
on
Still working beautifully in 2022! Thanks for creating this!
