Example Code
Creating Boxplots Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
This example demonstrates how to create box plot for interpreting the distribution of data.
Description
Data can be displayed in many ways in LabVIEW. One method of displaying a set of data is with a box-and-whisker plot: also known as Boxplots. These plots are helpful in interpreting the distribution of data. Rather than showing the entire dataset these plots produce a five number summary consisting of the median, the quartiles and the max/min values in the distribution.
On the NI Developer Zone, there is an article concerning this, NI Developer Zone: Boxplots and Stem-and-Leaf Displays. The article contains a VI library which takes in a 2D array and generates the plots on an XY graph. The article also covers how the VIs work.
Requirements
Software:
  • LabVIEW 2012 (or compatible)
1. Run VI.
2. Observe the plot regarding your inputs on the front panel.
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
Comments
ron_wood
Member
Member
on
http://zone.ni.com/devzone/cda/tut/p/id/3047#toc2
Figure 2 depicts multiple boxplots on one graph..
but it is completely unclear how to do this, there is no multiboxplot implementation example anywhere.
Figure 2 should have been an example!
Hillman
Active Participant
Active Participant
on
Hi Ron Wood,
I no longer work for NI so I would recommend posting your question on the forum or contact your local sales office.
However, at the time I did make this work with multiple plots. I think all you need to do is expand the data input control as its a 2D array. The format plot subVI should resize the graph to display both plots.
Hope this helps,
James
Kind Regards
James Hillman
Craig_
NI Employee (retired)
on
I spent some time improving this code, you find a version which supports multiple plots here:
https://forums.ni.com/t5/Example-Code/LabVIEW-Box-Plots/ta-p/3506533
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
